Does the radio for the s model 2015 comes with a port for rear speaker since I notice on the radio menu it has fade to put the sound coming from the back?
I think it does come with a port for the rear speakers as I would think the standard radio for the S, S+ and SV models are one and the same (S+ and SV come with 4 speakers). However, as one owner has recently posted, he lost the use of the audio steering wheel controls when he wired his speakers. Honestly do not know what happened.
Did you ever fimd out if it did. I seen some 2014 radios that look like the 2015 versa ones that had the rear port for the speakers .
I have a question hope someone can help I have a note S plus, my car does not have the audio controls in the wheel it only has the cruise Control can I be able to set up a audio controls for the radio?
Anything is possible. It only depends on how many parts you need to change to make it work. I would think at least a new steering wheel (they probably won't sell you just the switches), probably a new clock spring (to connect the switches to the wire harness that connects to the radio), assuming the wires are in the harness, of course.
