21 - 27 of 27 Posts
Discussion Starter #21
Would u know if that is can be fixed during a routine tire rotation or if the dealer had to do?
Discussion Starter #23
I went to wrong dealership so missed appt. can t begin to explain how that happened. Unresolved. Need to rebook
My issue has stopped. I caught our grounds/lawn mowers using a leaf blower the other day near my car. He was blowing dirt, leaves, and other crap right into my wheels. Once cleaned the noise has stopped.
I suspect brake backing plate. If you mention it at your appointment they can check and bend it back if needed.
A rust ridge forms on the brake rotors and ends up rubbing on the plate. Super common and easy to fix.
Of course it could be other things. Just a guess!
Sent from my Moto E (4) Plus using Tapatalk
Somebody needs to check the stabilizer bar and its' workings. The bar only warps at turning and then the inside reach of bar may rub something, could be very simple to fix. Or an end link that only makes noise when fully stressed, that also only happens at turning.
21 - 27 of 27 Posts
