1 - 13 of 13 Posts
Has anyone attempted to put a radio from a 2020/2021 Versa SV/SR (a radio with CarPlay/Android Auto capability) into a 2020 Versa S (no CarPlay/Android Auto)? I've seen a few for sale from crashed SVs/SRs for sale for a few hundred bucks, and I am curious as to whether this could be a plug and play upgrade, or if it would be a major PITA.
Thanks in advance!
I've been tracking this from a slightly different aspect too. I have a 2017 Sentra that I want to put the Carplay/Android unit in. I'm dealing with a supplier change and different wiring harness, but for a same-model-year swap, it may be the same harness. Nissan changed radio suppliers from Panasonic to Bosch for the Carplay/Android radios on pre-2020 models, but I'm not sure if that's still the same case for the 2020s without Carplay/Android.
I have also seen where some car manufacturers built the feature into the USB port hub.
Discussion Starter · #4 ·
Update: radio from the SV fits in the S, and works perfectly fine (including CarPlay), but the backup camera doesn’t work. Will keep investigating and post and update if I figure it out.
you need to pull wiring diagram for both S and SV, and check if the pins match in both models. You might have to reroute a missing pin or swap it. the diagrams will help you do that.
Or maybe they read a different voltage and that makes you lose some functionality.
Thanks, makes sense. Do you know where I could find these? I did some googling and came up empty
I'm not entirely sure because your model is very recent, but worst case scenario you can buy one at nissan-techinfo.com
I believe it's 19$ and you can download it and have a CD with links etc.
Oe you can go ask your dealership..if they are nice enough they might just print off a copy.
I have a couple questions,
Can you tell me where you purchased the radio and found the others? I’m searching eBay and every salvage yard I can find with no luck. I’m trying to do the same thing on my 2021 Versa S.
Have you figured out the back up cam?
Hey! Sorry to revive this thread, but am definitely curious if the backup cam situation is resolved here. I'd also be curious to implement such a swap in a 2021 Nissan Versa S.
Thanks in advance!
I have a 2020 nissan sv the radio is 7 in wide i believe but has a bigger box in the back that i noticed from diffrent radios that looked like it because my car has to wiring harnesses for the radio
1 - 13 of 13 Posts
