1 - 1 of 1 Posts
Item:EUP40A-1W24V-1
Input Voltage:100-240VAC
Output Curren:1.7A*1Channel
Output Voltage:24VDC
Output Power:40W
Dim Mode:1-10V/0-10V
Model: EUP40A-1W24V-1
Feature:
-Single channel constant voltage 24VDC output
-Support 0-10V/1-10V analog dimming signal, Passive or active signal.
-Dimming range from 0-100%
-Wide range voltage Input 100-240VAC
-High efficiency: up to 86%
-Dimming effect smooth, no flicker
-Over load protection , over voltage protection
Specification
Model
EUP40A-1W24V-1
Output
DC Voltage
24VDC
Current
1.7A/CH
Rated Power
40W
Voltage Tolerance
±3%
R & N(max)
200mVp-p
Channels
1
Input
Voltage Range
100 – 240VAC
Frequency Range
47 – 63Hz
Efficiency(Typ)
≧86%
Power Factor(Typ)
≧0.5 (@220V)
AC Current
[email protected] & [email protected]
Leakage Current
<1mA @240VAC
Inrush current
[email protected]
Protection
Over load
Close output, recovers after fault condition is removed
Over voltage
Hiccup mode, recovers after fault condition is removed
Function
Dimming
0-10/1-10V dimming (passive or active)
Others
Dimension
122 (L)*78(W)*32(H)mm
G.W.(g)
220g
Packing
469(L)*281(W)*234(H) mm;50Pcs/12kg/Carton
Working Temp
-20℃ - 50℃
Euchips LED lighting drivers
1 - 1 of 1 Posts
