Took the 5 speed manual transmission out from my 2013 Versa for a clutch/slave cylinder job. The car was on 1st gear before the disassembly. The shifter lever is not in its 1st gear position any more as I moved it around while disassembled. Does any one know what is the default lever positions for first gear? Tried to read the Technical Manual but for the RS5F92R but I'm more confused now. Any help appreciated.
Side Note: I am hoping the tabs will only go back in the levers on the 1st gear position when I reassemble the transmission with the engine.
