Ok, I'm going to post a quick how-to on this in here. I took some pics while I was working but I didn't think about doing this until now. Hopefully you guys are mechanically inclined.
I noticed 2 small differences after this installation.
1. I felt a small increase in the quickness of my accelerator.
2. And I don't know if it's just me, but the vibration in my brake pedal that everyone's talking about lessened.
Now, I did all the work at my local auto hobby shop, so I had some weird tools at my disposal.
I used:
-Impact wrench
-Serpentine bet tension wrench (or a long wrench)
-Pulley pulling kit
-Flathead and phillips screwdriver
-10mm socket wrench
First thing you need to do is raise the car to take off the front-right wheel.
All these arrows point to where you need to remove push pins or screws to remove the wheel well.
Basically just remove anything that you need to in order to take that whell well off.
Now the picture above is a little hard to see, but the pulley that the orange arrow is pointing to is the main pulley to replace.
The circle is around the hex on the belt tensioner.
Find the wrench that fits and turn clockwise. It's spring loaded so hold the tensioner as far left as you can and slide the belt off the the main pulley. You don't need to pulley the belt completely off all the pulleys.
The picture above shows the main pulley. First take out the middle bolt (orange arrow). I honestly have no idea how you would take this out without an impact wrench. I would look at videos on youtube of people using breaker bars, but an impact wrench is the easiest way to go.
A little oil will drip when you get the bolt out, but that's supposed to happen.
This is the kind of puller I used. Put the to smaller bolts into the small holes in the pulley (green arrows). Then slowly tighten the large bolt in the middle. DO NOT DAMAGE THE THREADS ON THE INSIDE. I do;t even want to think about how fu*ked you'd be if you did.
Once the stock pulley is out, slide the new pulley in, lining up the notch on the pulley with the notch in the block.
Then just reverse the process. Hand tightening the pulley bolt, then tightening with the impact wrench, opening the belt tensioner, sliding the belt back on, and locking the wheel well back up.
Hopefully this did it for you. If you have any questions, PM me or something.
