One thing I love about my car is the storage space available. For a tiny car it has decent room. I also enjoy a nice stereo, but won't give up any my precious space.
I decided to go with a pair of JL 10W6v2's. They almost 7 inches deep, so they're a little tricky to stuff anywhere. Using fiberglass I can get the most out of the space available.
I cut part of the plastic trim panel away so I could utilize the room behind it. Here's a picture all taped up so you can get and idea of the space.
Here it is with the aluminum put into place prior to the first layer of glass.
Here are 2 pictures to show the the initial shell. I know it looks like hell now, but after additional layers and trimming it it will be a lot prettier.
Here's the side:
Here's the front:
Here it is with the flush mount MDF ring in place. I had to test fit the sub and test it in the car a few times to get the ring in a spot where it wouldn't interfere with the cargo bin. After it is in place I used a thick glob of resin mixed with fibers to lock it in place.
Here it is with the initial wrap of fiberglass on the front
I trimmed it up and test fit the sub.
Here it is in the car:
I'm happy with the position of the sub, but the box sticks out about 1/8" further than I wanted. I'll remedy that later.
Next it's coated with a bondo & fiberglass mix and sanded and primered and the cycle is repeated until the shape is nice and smooth.
Bondo:
Primered:
Here it is after the final sanding and painting. I'll mount the subs sometime next month. I still don't have my amp, so it's no rush.
Here is the passenger side. I got lucky and the hatch floor mat can fit under it.
Here is the drivers side. I had to relocate the light for the hatch, but I was stupid and didn't check to see it it would be blocked. I could still change it, but likely won't. Also I made it w/o the hatch mat in, and it won't fit on this side. I can get the mat hemmed for cheap, or buy a Nissan one that fits perfect.
Here are both in the trunk. The tape is still on them and the car is still apart, but it will be back to new this week.
Overall I'm happy with how they look and fit. Hopefully the sound will be good too. They are .60-62 ft^3 each and I'll stuff them with poly fill. JL suggests a box of .693 ft^3 and said within 10% is good, so with the poly I should be good.
I'll update this thread as my work continues. I've touched up the paint and will add pictures soon with the subs mounted.
Here's the side:
Here's the front:
Bondo:
Primered:
