The ABS light is flashing in my 2016 Versa SV. I took it to autozone to get the code read and they came up with a C1115. The report printed by autozone says "C1115 ABS Power Relay Output Short Circuit To Battery" and lists no known possible solutions. I've checked all the fuses in the cabin and engine bay for ABS components, and they're all fine. I haven't been able to find any relays for the ABS, only fuses. Has anyone had this problem and know any possible fixes?
It might also be worth mentioning that a service manual I found online lists a C1115 error code as "Wheel Sensor[abnormal signal]". I also recently upgraded my sound system, got new tires, and have been disconnecting the battery frequently for service. I believe the light came on right after I installed the new sound system, but I could be wrong.
