Thanks for the reply i did watch before start up and the ABS light did come on for a few seconds.If you have it, you will have an ABS light on the dash at startup.
Also look at the right front strut tower and see if there is a ABS pump, or metering block.
My 08 hatch S model does not have ABS, I don't know if they are all the same.Is there any easy way to tell if your 08 versa hatchback has ABS or not? or is there some where to look. Thanks for any help
