im not sure if anyone has had the issue im having with my versa but here goes,
i have a 2008 versa sl hatchback, when i first bought the car last year it had a noise in the front end, i assumed wheel bearing so i took it to the mechanic, (not the dealer). he quickly figured out it was the passenger side wheel bearing by putting the car on the lift had me put car in drive and let idle while he held the driver side tire still, obviously since the noise was still there it was the passenger not driver side wheel bearing. the mechanic fixed passenger wheel bearing and no more noise, problem solved, BUT now my abs light is on, so he got his computer and cleared whatever code he found that threw the abs light, so the light comes back on not even 1 mile down the road, been on ever since, so what im asking is does anyone think that the sensor is actually bad because of the diagnosis method my mechanic used or is it something simple? if the sensor is bad how much of a pain in the rear is it to replace? the sensor is 35.99 at auto zone but for some reason sears wants 250.00 to replace. please help!!
