Hello Everyone,
My 08 Versa's AC compressor makes knocking noise when the car is idling. Doesn't matter if the AC is on or off. Anyone every see this issue and if so have a solution that does not require replacing the compressor.
Thanks in advance
Hello Everyone,
Thanks in advance
It might be the compressor clutch that is going south. With the ac off, that is the only thing on the compressor should still be turning. If it is the clutch or clutch bearing, it can be replaced without the entire compressor having to be replaced.
