I think i found what it is, tested them and they did go up can see much better but they need to be higher, the most intense part is still below the hood line
Have you tried getting a philips screwdriver and adjusting the white plastic screw located on top of the headlights? It's a little difficult to get to, but by twisting that screw, the headlight will aim higher or lower, depending if you tighten or loosen the screw. Good luck.I know this was 3 years ago, but would you happen to remember how to do it? I need mine to go down.
