I recently lowered my v on tein s-techs and replaced the shocks and struts. Do i need new alignment specs for when i take it in for an alignment, or will it be fine with the factory specs?
The alignment machine will have everything it needs on it. Running factory specs will more more than fine, especially on vehicles like these which dont really drop much
Actually you can adjust the camber in the front too.
They will line it up to stock specs. That will be close enough. Just because the car is a bit lower doesn't really change their specs. Don't let them tell you it will, alot of shops balk at lining up a lowered car just because they don't know. I had alignment problems when I first lowered mine, and after having a mechanic set it up as if stock it is fine.
