Hello everyone,
I just installed the new Pioneer AppRadio 2 head unit in my 2008 Versa Hatchback, and I am now trying to figure out how to run the MHL wire to connect my Android phone to this unit, and what I want to do is run the wire down through the center of the dash and have it come out at the bottom where the 2 front cup holders are, in front of the gear shift (I have the 6 speed manual transmission Versa). What I can't figure out is how to get the front dash off the car. Is there somewhere on these forums that either explains or shows how to remove the dash? I already have the unit installed, just need to figure out how to remove the entire dash to do the wiring. Thanks!
I've attached some pages from my service manual, it should be able to help you out.
As for the center dash, around the instrument panel you need to remove the panel below it first, pry it open using a trim removal tool (pry it below the A/C panel piece and above the bottom piece). Behind that are two screws holding onto the A/C piece, remove them and it comes out normally.
im more interested in how you got that silver dash on there??
Looks great!!! lol
lol thanks. I got it from Ebay from domesticparts it is factory matched color although it's much much shinier so it may not look like it in the picture. They also carried Satin Nickel and Carbon fiber kits. I love it.
Oh I also should add but these dash kits don't have that extra polyurethane clear coat layer on them, so the dash kit isn't that thick like some.
