1 - 8 of 8 Posts
FYI only:
If you have been considering buying a code reader I can recommend the inexpensive AUTEL MaxiLink ML329 (grey color). You can pick one up for approx $30-$35 on eBay etc
Read & delete codes
"Live Data" capabilities to for example monitor cataylic converter upstream and downstream O2 sensors (real time) Plus many other functions.
I like the one buttom I/M readiness button to be sure your vehicle is ready for official "plug in testing". You can actually plug it in while driving and when the car is ready for inspection a green light comes on.
Neat little scanner for the money. I even keep an extra one in my glove compartment to help other drivers or if looking at used cars.
That is cool if you can see some live data at that price. I've got a cheap generic one I got off fleabay or amazon years ago that I keep in my glove box. It wont do live data as far as I know.
Discussion Starter · #3 · (Edited)
I'm telling you for the price and features they are great with full live data etc, both of my son's have them also. Do a Youtube search and check out the demos. That one button I/M test is great if you are trying to determine when your car is ready for plug-in inspection (before that drive cycle triggers the final MIL).
That's what is so confusing about these Autel products.
I wonder what the difference is between the ML329 and the AL319. They look to have the exact same features, except the AL319 is ~$7 less.
Discussion Starter · #7 ·
Discussion Starter · #8 ·
There is more info but this may help:
Autel ML329 OBD2 Scanner Advanced Version of AL319 Code Reader AutoVin Function Engine Fault CAN Scan Tool with Patented One-Click I/M
After checking out the Autels..for about $30 more I might pick up either the ML529 or ML629 to check automatic transmission, air bags, seat belt, ABS, component tests etc...then for another $30 you can pick up even better scanners! Need to stop looking:)
1 - 8 of 8 Posts
