1 - 13 of 13 Posts
I took a chance and did a little research. And compared the 2nd gen to the versa note, and found the springs are exactly the same. So i got the b&g springs for the note.
It dropped 30mm so far fron and rear, waiting for them to fully break in.
Thanks for the link from your other post. I checked nissanpartsusa and show the same springs too.
Not sure what the fits year range issue is. Mine has a 10/13 manu date. Was the spring change due to the breaking spring recall?
Anyway, I ordered the B&G's off ebay just now. Will post pics when done.
My box from B&G came in tonight. Hoping to install on Saturday, weather permitting.
One question but I think I see it in your photos. The front coils go in with the tighter/closer coils towards the bottom?
Any tips, tricks or caveats would be greatly appreciated.
Discussion Starter #8
The rear is very simply all you have to do is unbolt the shocks at the bottom, and lower the axle, and the front you can use a spring compressor or try to put your weight on it and have some one else unbolt it with a impace, but the new ones you dont need to compress the spring to put it on. I did it in about a hour, but i had a lift and a spring compressor
You were right, the kit fits dead on. The only issue I had was that I didn't have a real good wrench to get on the top strut retaining nut. Coming from Ford's and Chevy's, my box is a bit weak on the larger metric stuff. Time to buy more tools.
Whole job took me about 2.5 hrs. I don't have access to a lift so it was jack and jackstands on a slanted driveway. The time includes the 15 min of crying time when the end of my ratchet just barely tapped the edge of the fender and put a small chip in the paint. These things have some real thin paint on them. I have some touch-up in transit from Amazon.
Here's a link to the photos, this kicks off a new project. http://tinyurl.com/hb5xh7s
1 - 13 of 13 Posts
6 Participants
D3R3K
