Hey Guys my 2007 has gone through 3 belt tensioners I've even tried a slightly smaller belt but it still bounces back and forth like crazy . None of the pulleys are bent and it makes the car sound like its falling apart. Any suggestions on where to look or a name of a good brand to install.
Thanks
In the past, I've used Gates brand (spring loaded) belt tensioners.
My current Versa has a manual tensioner, where you adjust a bolt to provide proper tension to the belt.
As a suggestion I would clean all the pulley surfaces and check the other pulleys for play or noise (replace if necessary).
I'd also go with a new Gates brand belt. I've had really good luck with Gates for these items.
Just my two cents...
