Have you looked underneath the dash from the pedals? Maybe find a grommet to pierce through?
Yes, I've found where the pass thru is under the dash and in the engine compartment but I would rather push from the engine side so I don't have to remove the in-line fuse from the amp power cable I bought. I may just have to suck it up and push thru on the dash side and just reattach the in-line fuse to the power cable once I'm through....Have you looked underneath the dash from the pedals? Maybe find a grommet to pierce through?
we may be talking about the same point, its on the drivers side. i think to the left of the steering column, a rubber grommet with a bunch of wires in black tape going through. thats where i fed my 4awg power through, worked perfectlyThanks for the info OneGoldfish!
I'll have to try it that way tomorrow when I get started on it. So your basically saying that there should be two pass thru points on the firewall? One for that giant bundle of cables and one next to the steering wheel? I didn't see the second one for some reason so I'll have to take a look tonight and see what I missed. I appreciate your help!
I think we are thinking about the same place. I was able to get a coat hanger through that big grommet on the inside of the car & was able to grab it from the engine compartment. I tried to tape the amp wire to the wire hanger and pull it back through but it kept slipping off and would never come through. I'm only using a 10awg wire so I don't know why it's so difficult to pull it through. Did you feed the wire from the inside into the engine compartment?we may be talking about the same point, its on the drivers side. i think to the left of the steering column, a rubber grommet with a bunch of wires in black tape going through. thats where i fed my 4awg power through, worked perfectly
Thanks for the post, that makes it look really simple to do! Did you have to get under the car at all? Or could you grab the cable from the engine compartment?I actually used this post from nico to route my power cable through that grommet.
Amp wiring help. : Versa General Chat
Hope this helps!
I did that on my last car too. Could you take a pic?What I did since I have a manual car is when you open your door there is a small hole where the windshield meets the dash kind of? It's right underneath your side mirrors and I took mine through that and covered it with a black plastic cover so it isn't an annoying red wire right there in your face, it's a pain getting through that hole so if you wanna say fck it and worry about that another day so you can listen to your subs now you can do that.
I used a flat sewer rod (possibly 1/4" width that my dad owns) that I passed though the cabin out to the engine compartment with my sub power cable taped (weaving around the air box and not taking it out). We then took the sub power cable off, taped my 4 ch amp power cable to the rod, and pulled the rod back through.I think we are thinking about the same place. I was able to get a coat hanger through that big grommet on the inside of the car & was able to grab it from the engine compartment. I tried to tape the amp wire to the wire hanger and pull it back through but it kept slipping off and would never come through. I'm only using a 10awg wire so I don't know why it's so difficult to pull it through. Did you feed the wire from the inside into the engine compartment?
i fed the wires from inside to the the engine bay, had probably 6 inches worth tightly taped onto the end of of the hangar, i pushed the rest of the hangar through first and then pulled the wire through from the engine bay. i cant understand why it is slipping off, becuase it worked for me on the first try, handy little trick my dad showed me. however as he was slowly pulling on the hangar wire, i was slowly feeding the 4awg wire into the grommet, so that likely highly reduced the friction issues in that area.I think we are thinking about the same place. I was able to get a coat hanger through that big grommet on the inside of the car & was able to grab it from the engine compartment. I tried to tape the amp wire to the wire hanger and pull it back through but it kept slipping off and would never come through. I'm only using a 10awg wire so I don't know why it's so difficult to pull it through. Did you feed the wire from the inside into the engine compartment?
