21 - 30 of 30 Posts
it pops right off. i used stuff called plastidip, comes in a spray can and stick to plastic without sanding. its just a spray on rubber coating and withstands alot of abuse
Someone on here recommended using fishing line to remove the emblems. I tried it yesterday and it worked like a charm. Works best if you're in hot sun or use a hair dryer. I also tried Plasti-dip, that stuff is easy to screw up but the good side is all you do is peel it off and start over. I would be confident enough to spray it directly on my car. After it dries just peel it off as long as the surface is clean and smooth, it is however not glossy.
front emblem pops off with clips like this
rear emblems come off with fish line/hair dryer/goo-gone etc:thumb2:I think
21 - 30 of 30 Posts
