Got this off another versa forum:Hi,
I took the Versa (now with 55,000 miles on it) to the Splashes car wash. But when I drove away, the airbag light started flashing. Has been flashing ever since. What is wrong and is it an easy fix?
Thanks
PS. Its a 2012 Versa S
Awesome, glad you found a solution and posted for usThanks. I tried all that but then I read somewhere that someone had something similiar and it was because one of the seats was unplugged. So I looked under the seats and the passenger seat was unplugged. Light isn't blinking anymore.![]()
Yes, and I know someone with a 3.6 Avenger. I need to get him to Cayuga Dragway to see who can get their groceries the fastest...^^^
The Police package has a column mounted shifter. Even more reminiscent eh?
You have a 3.6 Charger don't you? They're generally good motors, lots of power, there was an incident with the heads (valve seats i believe) around your year but only a few.
I second this technique. What actually happened to mine was my passenger seat was unhooked below(wires) i reconnected , still had blinking. But after this method. Nada. I was good .Got this off another versa forum:
1. Turn the key from off to on(not ACC).
2. Watch the airbag light closely. It will stay on for a few secs. and then as soon as it blinks off (the start of the flashing), turn the key off instantly.
3. Count to 5 secs(1 Mississippi, 2 Mississippi . . . .)
4. Repeat steps 1-3 two more times until you have done the cycle three times.
5. Now turn the key on and watch the light. It will start blinking in a different, slower manner. This is diagnostic mode. You can watch this for a little while, no hurry.
6. Now turn the key off again, Count to 5 like in step 3 again, and turn back on. If the procedure worked, the airbag light will not be flashing.
Sweet man. This worked for me.Got this off another versa forum:
Yup, this did it for my Nissan versa 2015. I unplugged the socket behind the center vent while installing my after market stereo, it started blinking. Did the steps above, I turn off and on maybe 10 time and it finally work.Got this off another versa forum:
Does your 2019 Versa still have 3-year/36,000 mile warranty?I am having the same problem did the count off and my airbag light is still on 2019 versa, trying to avoid that 130 dollar diagnostic, do not know what todo
