I doubt they are using a drastically different brake fluid. I saw that too, and was surprised also. But I try to change my brake fluid once a year regardless, so I wasn't concerned.
good for life under LIGHT operating conditions, the service manual goes on to say that the CVT fluid should be changed every 60,000 miles under HARSH operating conditions i.e. stop and go traffic, extreme temperatures and the like. also, ever since i can remember it has always been a good idea to change out your brake fluid once a year as like someone said earlier, it attracts moisture and i feel that Nissan is including this in their manuals now because it would be a liability to them if they didn't...all that it takes is that one sue happy person to not change their brake fluid and have their brakes fail and blame it on NissanHmmm interesting. Yet Nissan says the CVT is is good for life. :banghead: Thats far from the truth. Since brake fluid attracts moisture it is good to do once in a while. Like most people, I do a thorough flush when servicing the brakes. Thats more than most people, and I've never had issues. I do intend to do the CVT flush around 30k or so. I will keep an eye on how it looks.
Every shop that does quality work should have brake fluid test strips. All they do is dunk the strip in the brake fluid to see how much water and copper content is in the fluid. Then it is compared to a color chart to see if it should be replaced or not.Sorry for the bump, but I was hoping someone could give me advice. Brought my car in for an oil change and Nissan wanted me to do the brake fluid change as stated in the manual. Passed on it since it seemed like 20k miles is overkill for replacing the brake fluid. What is the census for replacing brake fluid? Is it also worth getting these services done at the dealer and spend the extra amount or go to a smaller shop and hopefully save some cash?
For the 2014 Note, the maintenance requirement is replace the brake fluid every 20,000 miles or 2 years. The Note uses DOT3 fluid. No idea on how many quarts are needed.So Nissan asked for and brake fluid change waaaaaaaaaaay earlier than 20,000 (car just turn 33,000 tonight and now just turned 15 months old), maybe they asked for the change before 15,000 but I don't remember correctly, but anyways, my question. What fluid does it use and how many quarts does it use?
Yes there is a way to check for brake fluid contamination but the maintenance manual for the 2014 Note does not have a provision for checking the brake fluid. It requires brake fluid replacement every 20k Miles or 2 yrs.Every shop that does quality work should have brake fluid test strips. All they do is dunk the strip in the brake fluid to see how much water and copper content is in the fluid. Then it is compared to a color chart to see if it should be replaced or not.
I would ask your service person to perform this test is they can. Note, this should be a FREE test. At Firestone Complete Autocare we tested every vehicles brake fluid at no charge for pretty much any service they came in for.
