Replacing the rear drum brakes and need to replace the little spring clip that holds the hand brake
lever to the pin the the top of the brake pad. The hardware kit doesn't have anything like it, but has a spring washer and U clip I don't see on the original brake set up. Am I correct to assume that spring washer goes under the U clip to replace the original?
First pic is what was on the brake, Second from the kit
