HI all,
I am facing a problem when hitting hitting the brake where i feel a steering vibration. I have been told that i must replace the brake Rotor, the brake pads are new. so what is the minimum thickness or diameter for the brake rotor for nissan versa 1.6? please advice.
No clue but you can look in the FSM and it might even be in the owners manual. But around me at least finding someone to machine a rotor can be tough. Then add in the downtime and it's not even worth it. I would just pick up two new rotors and slap them on yourself.
HI all,
Per the factory manual for the 1.8 should be the same w/1.6 is the Rotor is 24mm and minimum is 22mm and easy to check if you have a 22/24mm wrench. Might check a local parts store like a Autozone or PepBoys in your area, they can usually turn rotors if necessary or point you in the right direction.
Hope this helps and good luck.
