My brake warning light comes on when I'm making tight turns at high speeds. I popped the hood and checked my brake fluid, and it looks like it's close to the MIN line. Should I get my brakes checked or try to top off the brake fluid first?
edit: Did some more research, and looks like the worst case scenario is that there's a leak in the master cylinder. Right now I'm thinking that the brake fluid wasn't at max when I got the car, and now the pads are a little worn, causing the fluid to go down slightly. I'll add some more so it's slightly below the MAX line and see what happens.
