Hi Everyone,
I am new to forums so I hope someone can help me out here. I have a 2010 Versa 1.8S, automatic transmission. It has about 40,000miles on it. Recently when I put the car into reverse it revs as if it is neutral, you can see the RPM's going up but the car doesn't go anywhere (and yes the parking brake is off). I put the car back into park and then put it into reverse and it does the same thing. The only way I have been able to fix this problem is to turn the car off and then turn it back on again. Which is very frustrating since a car should not have a problem going into reverse. This same problem has happened when I go into drive but only twice were as it has been a couple dozen times with reverse. I have checked the transmission fluid b/c I thought that maybe be the problem but that is fine. Let me know if anybody has any ideas on what could be causing this problem. Hope to see some posts soon
Thanks!!!!
Thanks!!!!
