Whenever i stop and leave it in drive i hear a rattling sound coming from the engine area. Its only when i press the brakes and not when its in neutral. Here is a video i took. Shit broke
Nah the thunk your hearing is me pressing the brake you really have to turn up your volume to hear it like all the way and listen closely its a continuous rattle and it happens in drive and low and reverseI think I'm hearing a "thunk" in the video. There is also some traffic noise in the background, so I'm having a hard time hearing a rattling sound.
Any who... As far as a "thunk" sound I would start with a visual inspection of the motor mounts and trans mounts.
If you are trying to track down a "rattle" sound, look at the heat shields around the exhaust system.
Maybe you can have someone hold your phone/camera near the engine area when you press on the brake.
In the video you have the car in "Low". Does it make the same sound in "Drive" or "Reverse" or only in "Low"??
How about Park??it happens in drive and low and reverse
Nope not in neutral or parkHow about Park??
Ok so i have a 2016 versa note sv with the cvt. 74k miles and it doesnt happen when the parking brake is up onky when i press the pedal.OK... good.
Well two things happen when you shift from park or neutral into a motion gear (drive, reverse or low) you are engaging the transmission and putting a load on the engine.
If the motor mounts are worn out, the engine can move slightly, thus something that isn't touching (like a heat shield or some other part) will move & can rub against something else -- thus you get your rattling sound.
The other possibility is something has gone wrong (internally) in the transmission.
The rattle does not occur with the parking brake on and the car in Low, only when you press the brake?? Can you clarify?? I want to rule out a vacuum leak on the brake booster or brake booster hose.
What year is your car?? How many miles?? Do you have a CVT transmission??
I've got a few more questions, but lets try not to condemn the transmission as this may point you in the wrong direction.
Yes they do i wont be abke ti respond for about 45 minsAgain... good.
Are you having any issues with the brake lights?? Do they all come on when you press the brake pedal??
Let me look up some information on the brake booster. I'll be back in a couple of minutes.
Please do and ill post results after thanks for all the helpOK... I looked up a few checks for the brake booster for "air tightness". They are not all that complicated but do require you to run the engine two minutes and do a few tests.
I can post them if you want to try them (later) and you can tell me the results.
In reference to the new ringing sound, were you in Park or Drive??i did notice a very high pitch almost ringing sound when i stopped earlier which wasnt there before
Drive it behaves just like the other sound but on top of it nowIn reference to the new ringing sound, were you in Park or Drive??
Mine only does it on drive but that sounds of that video I'm seeing very loud mine is very lesser sounds tapping so maybe it from bumper lose or something but has mechanical I don't think something is wrong what's your suggestions??I think I'm hearing a "thunk" in the video. There is also some traffic noise in the background, so I'm having a hard time hearing a rattling sound.
Hey have the motor monts checkedWhenever i stop and leave it in drive i hear a rattling sound coming from the engine area. Its only when i press the brakes and not when its in neutral. Here is a video i took. Shit broke
Hey have your motor mounts checked I have 2014 versa sv sounds like same rattle my car makesWhenever i stop and leave it in drive i hear a rattling sound coming from the engine area. Its only when i press the brakes and not when its in neutral. Here is a video i took. Shit broke
