Well I have decided it's time to upgrade my ICE from a stock S model radio. I really wanted a way to have my screen hooked up to the OBD system so I can monitor things and check codes. I can't seem to find anything like that unless I go carputer. I know nothing about any of this stuff so maybe you guys and gals can assist.
My carputer idea (which may not work IDK) is as follows. I will be using a laptop hidden in the glove box or under the seat. I will run a double din touch screen off the laptop and mount that in dash. I will us a USB gps antenna and USB FM tuner for radio station. Since the screen uses USB as well I will have to find a unit with at least 4 USB ports. Do they make that? I will just have to find a way to turn the laptop on and off remotely as well as find a way to power it. A quick google search gave me a ton of ideas so it shouldn't be too hard.
The in dash nav unit would just be like a pioneer f700bt or something cheap and similar. These indash units do everything I want except auto diagnostics. If there was a way to incorporate that into one of these units I would go that way. Much easier to do and easier to use.
So please give me thoughts and opinions on this. Thanks
