It's recommended to change the intake gasket when you change the spark plugs. If you didn't you may have a vacuum leak bad enough the car won't start and run or runs poorly. There are also several hoses and I think electrical connectors that have to be removed to change plugs in the newer models. Have you double checked to be sure you have everything hooked back up correctly?
