Just a few things I've noticed after a period of time owning my car.
-My driver's power window is super fast. Its all the way down before the back windows are halfway. Passenger front window is pretty speedy too. Do you think since it's the main window (driver's) they put in a more durable motor?
-My steering wheel is cocked slightly to the right to drive straight. Yes, I realize everyone goes straight to bad alignment. While I of course cannot make it PERFECT, I have taken every precaution. I have a 5 year plan with NTB, as many alignments as I want from any store. 2 sets of tires, and 2 different NTB's (both stating alignment was fine to start with) and steering wheel still cocked to the side. Not bothersome. Just different.
Now to the questions.
I was vacuuming out the car today when I noticed the back seat had some wiggle to it. By reaching one hand under, I was able to lift the whole back seat up. There was one clip that popped right out, I was amazed at how easy it was. Are they all like this?
I know that due to laws headlights have a cutoff pattern to reduce glare to oncoming drivers. For some reason I feel like my drivers headlight is too low though. The drivers beam cuts off maybe 10 feet shorter than passengers and that seems excessive to me.
Edit: I went and took off the headlight assembly to check and see if it was mounted properly as I had changed the headlights out as soon as I go the car. As far as I can tell, it's mounted correctly so I'm not sure where the problem is. Suggestions?
