My condensed steps from the Versa FSMi'd like to do this but have never done it before, anyone have a step by step to help me out?
I know this has been posted a year ago but I do have a issue heres what is happening. i own the car for a year but just weeks from now when i drive a few miles and turn of my car i noticed that there reservoir is boilin and has a sound together with a white smoke. I check and opened my radiator cap and white smoke was coming out as well and it was empty...is this an issue on the reservoir or do i have to replace any part here?My condensed steps from the Versa FSM
1. Raise the car on jack stands
2. Make sure the engine cool then remove the radiator drain plug under the radiator, then the radiator cap
3. Remove the coolant reservoir tank and drain it
4. To flush coolant, fill the radiator and reservoir tank with water (a coolant flush additive is only required if you're experiencing really bad coolant build up or rust in the system, which hopefully you shouldn't lol)
5. Run the engine until operating temps, then rev it 2-3 times
6. Stop engine and let it cool, then drain the water
7. Repeat step 4 to 6 until clear water drains from the engine
Did you top it off with coolant or at least water? Sounds like it's low on coolant and possibly the coolant is old and lost it's cooling properties and allowing the coolant / water to boil. I would definitely flush out the old coolant and add new and go from there.I know this has been posted a year ago but I do have a issue heres what is happening. i own the car for a year but just weeks from now when i drive a few miles and turn of my car i noticed that there reservoir is boilin and has a sound together with a white smoke. I check and opened my radiator cap and white smoke was coming out as well and it was empty...is this an issue on the reservoir or do i have to replace any part here?
