I've put about 12.5k miles on this note.
I was checking the coolant level, and it is very slowly going down.
When new it was right between the min/max marks, now it's about 1 inch above the min mark.
manual says:
manual says:
Do I need to be concerned?CHECKING ENGINE COOLANT
LEVEL
Check the coolant level in the reservoir when
the engine is cold. If the coolant level is below
the MIN level 2 , add coolant to the MAX level
1 . If the reservoir is empty, check the coolant
level in the radiator when the engine is cold. If
there is insufficient coolant in the radiator, fill the
radiator with coolant up to the filler opening and
also add it to the reservoir up to the MAX level1 .
If the cooling system frequently requires
coolant,have it checked by a NISSAN
dealer.
