I took a look under the hood and noticed that the coolant in the tank is low enough where I can't see anything. I remember in the old days there was only one kind of coolant, but nowadays there's apparently a bunch.
Does anyone know the kind the factory/dealer would have put in the 14 versa note SL? (Bought the car used and it's not in the manual).
From page 308 of the owners manual:
When adding or replacing coolant, be
sure to use only Genuine NISSAN Long
Life Antifreeze/Coolant (blue) or
equivalent. Genuine NISSAN Long Life
Antifreeze/Coolant (blue) is pre-diluted
to provide antifreeze protection to -34°
F (-37° C). If additional freeze protection
is needed due to weather where you
operate your vehicle, add Genuine
NISSAN Long Life Antifreeze/Coolant
(blue) concentrate following the directions
on the container. If an equivalent
coolant other than Genuine NISSAN
Long Life Antifreeze/Coolant (blue) is
used, follow the coolant manufacturer’s
instructions to maintain minimum antifreeze
protection to -34° F (-37° C). The
use of other types of coolant solutions
other than Genuine NISSAN Long Life
Antifreeze/Coolant (blue) or equivalent
may damage the engine cooling
system.
system.
I might have a different manual then from the Nissan website... Since I bought the car used it didn't come with one.
https://cdn.dealereprocess.net/cdn/servicemanuals/nissan/2014-versa.pdf this is the one I have. There's no traditional page numbers, just section & page numbers. (Like 5-45, etc). I even tried searching antifreeze and nothing came up
