I have everything disconnected, but for the life of me, I cannot get the sensor removed. I can rotate it, but it will not come out. I have struggled with this for 2 days. Does anyone have the secret to getting this out?
Should be just one bolt to remove, the wire harness of course then the sensor is sealed in the hole by an O-ring, correct? A twisting and pulling action should pop it out. I hear you though. I've had those O-rings really fuse in place due to no lube on it and corrosion. Be it aluminum or iron.
Yeah, bolt is out, like I said I can rotate it, but no amount of rocking and pulling gets this sensor out!
Sounds like it's just rotating within the O-ring groove on the plastic sensor body and the outer surface of the O-ring is fused to the block. The sensor may break in the process, but it will come out. Can you get a pick or flat blade under the bolt flange on it for leverage?
Maybe to spray it with a penetrating oil (like PB Blaster) and let it stay overnight, for oil to work its way between the O-ring and the block.
Discussion Starter #6
Thanks guys for the responses. Perseverance, a small flat blade screwdriver, a mirror, and I was finally able to get the thing out. Phew, 7 hours. :(
