Much like the HS hybrid, NHSTA cites that the amount of fuel leakage following a rear-moving barrier crash "exceeds the allowable limits," and that this could result in a fire. While a fuel leak is bad news, it's important to note that this NHTSA test isn't simply a case of a simple crash test and resultant fuel leak – the government agency's methodology includes striking the vehicle from the rear with a deformable barrier at 50 mph with a 70 percent overlap. Post-impact, the vehicle is then spun on its longitudinal axis degree-by-degree for a total of 90 degrees, somewhere along which a fuel leak was detected. While any fuel spillage is a bad thing, we suspect you can put any images of the massively overblown Ford Pinto debacle out of your head right now.
