For those with failed or failing CVT's, did you ever have symptoms of a slipping transmission ONLY when turning right?
I had the CVT flush done at the dealer and my car only has 54k miles. Recently, when turning when and either accelerating or keeping the same amount of pedal movement on the accelerator it bucks (nothing too dramatic) and feels to "slip" then grab, then repeat the process a couple more times depending on how cold the car is and the amount of throttle input. Everything else is fine.....
Wondering if the dealer would even bother checking into it since the flush was 5 months ago. If not, i'll use the lifetime warranty on the CVT i suppose....
