2014 Nissan Versa Note SV
Hi! I have a 2014 Nissan versa Note model it’s the SV package with the CVT transmission, it’s been replaced once already at 130,XXX miles and it is now at 171,000 miles I have a local shop that does the fluid changes every 30k miles for $125 I wanted to as if anyone knows if this is normal. When the car is first started and put in gear it clunks, from park or reverse to drive it kinda jerks like back and forth just a little but only from park or reverse into drive, it also I wouldn’t say hard shifts but you can definitely feel it the first time it shifts every time from a stop like from 1st to 2nd gear is this just a normal transmission thing for them I’ve been having trouble with stalling and MAF and belt, I just don’t know if it’s normal for a CVT I’ve had the car since 150k miles and it’s driven the same since then it’s just recently having the maf and belt problems but they changed the fluid at 160k miles and they said it was clean and shifted normally it’s the same shop that replaced the tranny 3 years ago from Nissan brand new not rebuilt it was 4,000 dollars any help is greatly appreciated! Also is it normal for the motor to have a slight tick I can attach a video if needed it’s always done that as well I’ve been told it’s normal but I am unsure I believe it’s the 1.4L motor, THANKS!!!
Discussion Starter · #4 ·
mmmm...180,000 on my 16 cvt..and no that isnt normal..should be smooth..i have a 1.6,the valves are shims i think..not hydraulic so after many miles they will start to tick
Uh oh any ideas on what it could be or does it need another replacement it’s smooth as butter every other gear just the first shift it does from a stand still it’s rough and you can feel it because the rpm just drop’s completely and instantly it doesn’t smoothly shift down like the other gears does? I have been having exhaust issues and airflow issues I paid 2,500 for the car and I had to fix sooooo much as it was abused but the current tranny only has 50k miles on it was replaced back in 20’ I try and slowly accelerate as I thought that was what your supposed to do with a cvt
It has a 171k miles on the body and the previous owner drove it really really rough she was a old woman and the whole car didn’t have a straight body panel my profile pic the pass fender is the same but the rest was replaced. She wouldn’t change the oil until the press. Light came on and never changed the coolant or did a tune up I did all that when I got it and am the 2nd owner
