I use the CVTz50 app to read the CVTF deterioration date on the Nissan Versa. I got a reading of
Method 1: 7,227
Method 2: 115,637
Method 1 = is applicatible if cvtf deterioration counter is slowly increases when CVT tempoerature is above 50C (122F).
Method 2 = is applicatible if cvtf deteroriation counter never increase until CVT temperature reaches 90C (194F).
The car is driven in the short distances, but sometimes in hot weather. However the distance is usually less than 10 miles, so I don't expect the cvt would heat up a lot? Which method should I used? I believe that we should change if cvtf deterioration counter is over 210,000.
Another piece of information, the car is 7 years old but only has 17,000 miles. I contacted Nissan, who suggest that we don't need to change cvt fluid until the mileage on the schedule is reached.
I am thinking that we should change the cvt if the follow condition occurs
1. The car goes over 30K. 60K is the schedule, but I am trying to be conservative.
2. The cvtf deteroration date goes over 210,000 either method 1 or 2.
3. The car is over 10 years old, thinking that perhaps after 10 years, there may be some breakdown on the fluid.
What do you think?
Method 1: 7,227
Method 2: 115,637
What do you think?
