Your Versa still under warranty?Okay so this just started today...so everytime I turn on my headlights my dashboard lights go off. I haven't had time to do any tinkering but do you guys have tips on where I should start?
:idea: Hahaaa..I am such a [email protected]$$...i was cleaning my car this week and wiping down the interior and I gues switch my dimmer off...:rolleyes5:Start even cheaper then that and make sure your dimmer switch is all the way up![]()
you would be surprised....and for the record fuses dont half work, they either do or they dont
Woah. My dimmer switch is on the opposite side.. Did you change yours around?Top Right
I just figured out that mine weren't on cause when I installed my dash cam system I pulled out the long term storage fuse. I dash board lamps wouldn't light up! Verified the cam was installed properly. All I had to do is push the LTS fuse back in and bingo! All works again! So silly and simple! Hope this helps!Okay so this just started today...so everytime I turn on my headlights my dashboard lights go off. I haven't had time to do any tinkering but do you guys have tips on where I should start?
