Okay here's my story, I recently purchased a 2008 Nissan Versa and she said it had 162 thousand miles on it I decided to rebuild the engine so basically I've replaced the crankshaft main bearings rod bearings have the cylinder hone replace the Rings head-to-head surfaced and pressure tested replace the all the valves had camshaft Mike I now have on an average 214 lb of compression on each cylinder replace the coil packs do iridium plugs do fuel injectors and I'm still pulling a p0302 OBD OBD2 code on it and I have done everything that I could possibly think of to get that code to go away and I'm still pulling the same code and I'm just wondering if it could possibly be a glitch in the ECM
