Delrin is a hard plastic that is generally easy to work with. It would not wear, and would be basically the same as a solid mount. Although i feel it would isolate harmful frequencies better in a way that metal can't, and maybe reduce transfer to body/cabin better than a solid mount. I can get solid blocks of Delrin at Forest City Surplus here in London. All except the right hand hydraulic mount could be replaced with Delrin, they are all in need of something stiffer. This would eliminate movement and be rather cheap considering you are just removing the rubber. I would have to get a tranny mount out of a Versa to see how that would be to replace with Delrin, although i suspect simply a matter of comparing height and width dimensions and duplicating it. That mount works like this, the stud going through the rubber mount is attached to the tranny, and the mount bracket is attached to a bracket which is therefore attached to the frame rail. The rubber moves way too much which of course can cause binding in splines and CV joints during high load or aggressive shifting creating erratic power transmission and stress points.
Just my thoughts on it. I don't have access to CNC but i could probably rig up a jig with router to cut them out if anyone else wanted to try it out. Provided i have success in my own car.
