Status
Not open for further replies.
· Tribal V
IF DOING THIS MOD I HIGHLY RECOMMEND ADDING AN INLINE FUSE, AND (NOT AS IMPORTANT RELAY)
THIS IS WHAT YOUR GOING TO NEED,
THE BIG FOG LIGHT KIT FROM WAL-MART COST IS $18.98
THEN GET SOME RED AND BLACK AUTO WIRE COST IS FOR BOTH $5.56
THEN GET SOME GOOD OLD ELECTRAICAL TAPE COST IS $0.97
I GOT A DIFFERENT SWITCH FOR THE FOG LIGHT FROM MY OLD CIVIC BUT THE ONE IT COMES WITH IN THE KIT IS FINE, BUT HERE IS WHERE U CAN DO THE SWITCH AT
NOW FOR THE FUN STUFF TAKE OUT THE STOCK COVER WHERE THE FOG LIGHTS SHOULD GO,
ONCE YOU DO THAT YOU WILL SELL LIL HOLES GOING AROUND LIKE THIS
YOU WANT TO DRILL OUT TO THE END OF THE HOLE AND NO MORE, TAKE ONE LIGHT AND HOLD IT TO THE HOLE ON THE INSIDE IT SHOULD FIT SNUG, ONCE YOU DO THAT AND IT SUNG IN THERE I USED HOT GLUE AND THEN WAIT FOR ABOUT 10 MINS AND DID IT ONCE MORE TO MAKE SURE THAT IT WAS NOT COMING OUT.
AFTER YOU DO THIS THERE IS A LIL HOLE WHEN YOU PULL THAT COVER OUT, ON THE LEFT SIDE IT WILL BE UP ON THE TOP LEFT I RUN MY WIRES THROUGH THERE AND ON THE RIGHT SIDE I DID THE SAME BUT THE HOLD IN NOW ON YOUR TOP RIGHT, ONCE IN THERE TAKE THE GROUND AND GROUND IT TO A SCREW RIGHT BEHIND THE LIGHT ON BOTH SIDES LIKE THIS
ONCE YOU DO, I RUN BOTH LIGHTS TO ONE ANOTHER BUT I TOOK OFF THE FRONT BUMPER AND ZIP TIE IT TO THE BUMPER SUPPORT AND THEN I RUN IT TO THE BATTERY LIKE THIS
ONCE YOU DO THAT TAKE A HANGER AND GO IN THE CAR AND PUSH IT THROUGH THE HOLE BY THE STEERING WHEEL AND RUN IT THROUGHT THE DASH TO THE LEFT OF THE CAR TO THE SPOT THE FOG LIGHT SHOULD BE AND DRILL WHATEVER SIZE HOLE THE SWITCH IS AND PLACE THERE LIKE SO
ONCE YOU DO THAT YOU JUST ABOUT DONE, MAKE SURE EVERYTHING IS GROUND TO THE RIGHT SPOT AND THAT THE SWITCH YOU ARE USING IS DONE RIGHT PUT EVERYTHING BACK IN THE WAY YOU TOOK IT OUT AND YOU SHOULD HAVE THIS
YOU SHOULD SEE THIS
THIS IS JUST THE FOG LIGHT
WITH BOTH ON YOU SHOULD SEE THIS
NOW GO HAVE FUN WITH YOUR NEW FOG LIGHT KIT THAT JUST SAVED YOU $150 BUCKS AND GO BLIND SOME ONE CUZ THE LIGHTS ARE BRIGHT
IF YOU NEED ANYMORE HELP FELL FREE TO EMAIL ME AT ([email protected]) AND ILL BE MORE THEN HAPPY TO HELP YOU
· Tribal V
Discussion Starter · #3 · (Edited)
this for anyone that needs help no prank calls, ok text me at 910-366-5472 thats my cell text me any time ill help out as much as i can, just when you text please tell me who u are and where i know you from so i know ok thanks
Status
