1 - 9 of 9 Posts
I own a 2007 versa hatchback s . I need to remplace of driver rear door. My door is automatic with of controls right. My cuestion is. If I REMPLACE OF DOOR MANUAL INSTEAD AUTOMATIC WILL WORK . ?
if you new door does not have power locks I don't think it will lock/unlock automatically.
Yes, I think the rear driver side is easier electronically wide. Rear passenger door has a few more wires that go into the BCM so it might give your some issues.
Driver side should be painless, just won't lock/unlock.
Ok SO I CAN PUT IT LIKE THAT THAT JUST GOING TO WORK MANUAL RIGHT BRO ?
I should work like that without codes...but I've never done it, so I'm not sure.
Because the rear passenger door has several wires going into the BCM, these wires may cause you some problems.:)
true, but he has to replace the rear driver side door, the one with the most wiring is the passenger rear side (makes sense, BCM is on that side).
1 - 9 of 9 Posts
