Probably not a good idea with a CVT. If you're serious then, start in L, shift to D, and turn off OD. You can't have the OD off when you're in L, remember that. Otherwise I'm not sure what else to help you with, good luck.
Will I blow up my tyranny if I take it to the drag strip for fun? Planning to start in L and pin the gas to the floor. Neighbor tells me NOT TO DO IT, boyfriend says it will be "fine". This is just for fun. Should I go for it???Probably not a good idea with a CVT. If you're serious then, start in L, shift to D, and turn off OD. You can't have the OD off when you're in L, remember that. Otherwise I'm not sure what else to help you with, good luck.
