I need a duplicate key but Nissan says they have to reprogram a new key and it cost $98. I told them that I just needed a copy to get into a the car but they told me they were out of blanks. Ive been all around town but nobody has my blank to cut my key. I drive a 2014 Nisaan Versa 5-speed. I have a key now that looks like a regular key and it starts the car? (see pic). Does this key look like its "programmed" or have a chip?
Edit: I have a regular key too that looks chipped but I dont think it is.
There is no chip inside the key you posted.
FWIW, "Nissan" isn't the one giving false information, it's the dealerships...
My 2015 Versa Note S base model uses the DA34 X237 key blank.
Nissan DA34 / X237 Mechanical Key (KEYLINE) [KLN-BDA34] - $0.40 : American Key Supply, The Locksmith's Source for Keys & Tools
Looks like yours uses the same one or something similar. I suggest you find a full service locksmith. They should be able to cut you blanks for a few dollars each.
Here is a post I made in another thread yesterday on the same topic...
I have a 2015 Versa Note S, Manual Transmission, US base model. I went to a full service locksmith today to get a couple of spares made. Was told by the Nissan dealership (AutoNation) that my keys contained a transponder, but figured it would still be less expensive to go through my friend the locksmith...
To make a long story short, they put the key in the Transponder Code Reader machine, and VOILA! No Transponder Found!
He whipped up a quick copy using a generic DA34 X237 key blank, we left the original keys inside just to be sure, and BAM! My lil' Note fired right up! :thumbsup:
Contrary to earlier posts in this thread asserting that every Nissan under the sun now uses a transponder/chipped key, at least for my 2015 Versa Note S MT, the generic unchipped blank works fine.
YOU DO NOT NEED A CHIPPED KEY for the 2015 US base model!
I recently had copies made of the ignition key on my 2015 Nissan Versa 1.6 S and the blanks used are exactly what is linked to in post #2 of this thread. $1.50 each for copies. The locksmith was astounded that a 2015 model year vehicle didn't have a chipped key. Initially he insisted it had to, until he checked it on some device and saw that it didn't.
5 Participants
amc49
