This'll be sort of a CTRL+C CTRL+V of what I posted in the "What did you do to your Versa today?" thread.
Installed some knockoff BRIDE seats from Ebay. Turned out pretty well -- a lot of DIY had to be done. The seats came with sliders, however ended up not using them. Decided to use the OEM brackets and sliders from the stock seats -- just had to weld together some plates / tabs to have the seats properly sit on the stock sliders, as well as a tab on the side for the seatbelt. As far as connectors go, just removed all of the connectors from the bottom of the seats and placed them in the bottom of the new ones. As far as seat airbags, that's still a work in progress. I removed airbags from the side of the stock seats (surprisingly easy -- didn't have to tear the seats up to do it), and currently have them sitting under the seats and still plugged in (I'm aware it's not the safest location -- this is a temporary fix until I properly fit the airbags. This was just to get rid of the airbag light on my dash).
Hello,
I was at the dealer today trying to get my driver seat fixed but getting nowhere. Anyway, I was looking at their models out in the lot trying to calm my anger down before getting on the road and took a look at a Juke with leather seats. I didn't do any accurate measuring, but I think the...
I have a 2014 SL Note. I’m curious if anyone knows if I can swap the stock steering wheel with the wheel from the newer SR variant. It looks much nicer and thicker. Which I like. Any thoughts or recommendations would be appreciated. Thanks!
Sent from my iPad using Tapatalk
Hello
I'm the owner of 2015 sedan.
I was trying to change my in-cabin filter, so I tried to remove the glove box.
But the 2015 model has "un-screwdriver-able" space bottom of glove box.
I watched every videos or articles but there's no model like this and they were easy to take out.
Does...
I gotta 2015 versa sedan plus and wanna change the cluster to a better looking sv cluster. Is it possible for plug n play or will I have to modify the wiring?
