If you yourself replaced the alternator and battery, I would recheck your work. I am not questioning your ability, but make sure that all your connections are clean and tight. The next step if everything is o.k. with the connections, is to take the car into almost any auto parts store, and have the battery tested "under load". Even a new battery can be defective. Good luck!!
