1 - 20 of 36 Posts
Symptoms: Odometer not working. Speedometer not working. Cruise control no longer works. ABS light on, Brake light on, SES light on. (ABS has been down for over a year.)
Had computer scanned at Autozone and got P0500 Error Code - Vehicle Speed Sensor, but no parts suggested.
Checked on Youtube and found this one
. The guy warned that it is not CVT transmission sensor but should be the VSS sensor. However, he was using Nissan Sentra as an example.
Couldn't find videos or articles online about Versa VSS. Google has many pictures but they are very different from the part the guy in the Youtube Video was showing.
My questions are
1. Does Versa use a similar part to Sentra?
2. What parts need to be replaced in Versa to fix the P0500 problem?
Thanks much in advance!!!
Well, they dont really sell replacement parts. One option is to try a junkyard and remove various sensors to you see one like photo with a gear for your car. Most newer cars use the ABS sensors for cvt trannys to help regulate ratio for the cvt for power to the ground. This is why they say to unplug the abs unit to autocross or do a dyno pull. :surprise
ABS error could be various issues like a wheel sensor to the actual abs unit with the pumps and valves in it. Those normally do a self check when you start the car and check all the valves, pumps, etc before a code is generated. One reason you should religiously change your brake fluid in these newer cars.
If it is causing your ABS light to come on, it is more than likely a wheel speed sensor has gone bad as well. No idea what vehicle you drive but I would see if someone with a real scanner can pinpoint which wheel speed sensor it is. You can get them from $20-$60 online. Or, climb under the vehicle and see if one of the wires have been cut or whatnot.
Heres a link for other Nissans but im sure the versa is similar. If i had more time id check, but just go to a Nissan Parts website and find it for your vehicle.
https://www.youcanic.com/guide/nissan-cvt-transmission-speed-sensor-replacement
With so many lights on, best bet at this point is take it to a shop and pay the diagnostic fees to have it looked at.
Otherwise you will be throwing money at the problem without getting it fixed.
My car is 2007 versa. Last August I took it to a repair shop as the ABS light came on. They scanned the computer and found the driver side rear ABS sensor needed replacement. They replaced it, however, instead of making that sensor work, they brought my whole ABS module down saying no power to both rear ABS sensors and no ground to the left side. The ABS light has been on since them, but I didn't have other problems until last week. After searching online, I believe it is the speed sensor (VSS) that is causing all the lights to come on.
I looked up the VSS sensor that the guy shows in the video both on Auto Zone and Advanced Parts websites, but they both say it doesn't fit my car. I did find this output transmission speed sensor and both say it fits 2007 Nissan versa. So I've ordered it from carparts.com. I want to see if that is the problem. I'll give everyone an update no matter what the result is.
Discussion Starter #6
Just an update - as Autozone said that the part the guy uses in the attached video doesn't match 2007 Nissan Versa and I've unplugged all 4 ABS sensors, I think the reason that the speedometer and the odometer are not working must have to do with another speed sensor. That was why I ordered the transmission shaft output speed sensor as I said. The part arrived pretty quickly and I replaced the old one this afternoon. Unfortunately, that didn't bring turn off any lights or bring the speedometer/odometer back to life.
Did you own the car since new and this started? You could look for the VSS wire and see if it has a signal.
Have you flushed your brake system? Do you brakes feel like they work ok?
As I stated previously, pay a shop to have the car properly diagnosed.
Doing the "throw parts at it and hope it's fixed" method will get both very expensive and very exasperating very quickly.
+1. Call around, some tire shops like Merchants do minor repairs like that or Midas mufflers.
Some out of work mechanics work for hire on craigs list if you use that.
Strange there are no other codes;
Brake lamp could be parking brake isnt fully released or low brake fluid.
SRS lamp, something with the air bag, module or connector.
Check engine lamp, thats a wild card could be anything from loose gas top.
ABS lamp, wheel sensor, module or actual pump module.
Discussion Starter #10
I'm the second owner and I bought it in 2013. I've added about 70k miles since I bought it. It has been running very well even until the ABS light came on about a year ago. The SES light and the Brake light just came on about 3 weeks ago along with the odometer and speedometer stopped working. A scan at Autozone gave P0500 and P0455. I replaced the suggested canister purge valve earlier. And then replaced the output speed sensor. Neither has helped to restore anything so far.
Stop going to Autozone, they do not have the tools to properly diagnose what is wrong.
They only read codes that are set by the ECM. That's it, nothing more.
AZ can't diagnose the issues you are having.
You need a shop, or dealer, to do a proper diagnosis of the many problems with your car.
Yes, they cost money, but most waive the fees if you get the repairs there.
I have a scangauge 2 and can clear codes. Better odb2 computers car read sub codes as well as pending codes and access other menus such as for transmissions and air bags. For your speed issue you should see the D on your dash blinking to indicate a problem with the cvt.
Discussion Starter #14
I took my car to Muffler Man Service Center, which I trust, hoping they have a better scanner and could find more errors. Unfortunately, they also caught 2 errors - P0500 and P455. As I'd replaced the Canister Purge Valve as suggested for P455 and the output shaft transmission speed sensor, they didn't know what to do, either. They called Nissan and was told it was not very common but Nissan did see some of those issues. Nevertheless, Nissan didn't have a straight solution. Actually, I had scheduled to take my car to Nissan next Monday for recall repairs. When I mentioned all the issues over the phone, Nissan didn't even offer to help. So, I cancelled my recall repairs.
I will pick up my Versa this evening from Muffler Man Service Center and will just drive the car for short trips until it dies, which may not happen soon as it drives and runs pretty well with all the lights on. We'll see how many more days I can still drive it.
Discussion Starter #16
Nothing flashes on the dashboard and that gives some comfort about going on driving it. People say, if anything flashes, that means the issue is urgent and serious. Not that case in my situation.
What city and state do you live in? Maybe someone is near you can take a look?
Yes, my nissan dealer isnt too friendly. The last visit they were nicer, but between the way they behave and their high prices Im likely to never own a new nissan again.
Depending on your state you may get by with lights on your dash. Other than not knowing your speed all your brake related features should be disabled like traction control, skid, anti lock brake and force distribution. So basically you have regular brakes before computers were involved. You should notice the cvt behaves differently too as it uses the abs sensor to know wheel speed to better select the cvt ratio for speed, throttle, etc.
Some states stick a sensor up your tail pipe, others plug a computer into your computer port, others just check things.
I replaced all 4 wheel bearings and now I’m getting a P0500 A error code. Is there any way to tell which of the 4 wheels is generating the error? One of the bearings could have been put in backwards(if that makes a difference with the reading, I don’t know). I don’t want to have to press out each individual bearing to press it back in just to check if the code clears. Especially when I may be pressing out bearings that are fine. There was no indicators on the master pro bearings I pressed in to tell me if it was put in the right way. The previous bearings had rings. For all I know I could have damaged the speed sensor when pulling it apart. I’d like to at least focus on the problem wheel first, starting with the bearing and moving to the sensor. Does anyone have suggestions?
1 - 20 of 36 Posts
