My ‘11 Versa has a broken exhaust flange right before it goes to the muffler...I’ve seen to get a split flange that would fix it but with both flange pieces still stuck together due to severely rusted on bolts I can’t even get the bolts to budge even though I sprayed a massive amount of rust penetrator on them and let it set awhile..any tips or tricks to get the rusty bolts to come loose and come off would be appreciated
Muffler shop.
If you cannot resolve your issue then you will obviously spit metal grinding fragments all in your eyes if you go the grinder route. Permanent blindness is not a good outcome to fixing a muffler.
If the rust is bad enough the bolts will NOT be coming loose, you'll have to destroy anything to get it off there.
