I am thinking about swapping the fluids out this spring and was wondering which types you guys have had good luck with. I want to do the transmission fluid and the coolant. For the coolant im thinking I should just go with the universal stuff that they sell pre-diluted, but I'm not sure about the tranny fuild. I don't know if the generic "for most import vehicles" will work or if I should go with something else. Any name brands you guys recommend? I don't want to get bargain basement fluids and have it come back to bite me later on. I'm not all that worried about cost and I have the automatic by the way. Thanks guys!
I have used maxlife ATF and other then the smell have had no issues with it. Coolant I pick up bargain basement. If I'm feeling frisky and there is a deal I'll go with prestone. Of course you can always buy OEM fluids from the dealer too. It will cost you though.
Yes the maxlife smells absolutely horrible. Smells bad new and old. Smells like gear lube you would use in a manual transmission.
ewww. i've used gear oil before and it definitely has its own smell. any other ideas?
