Hi..
I created a thread for queries for maintenance of several fluids...
I'll also try answering any if i can.
I had few queries...
Referring to the changes mentioned on Nissan U A E (dubai & Northern Emirates) | Our Service Prices
1)Difference between Transmission Fluid Change and Transmission Flush
Nissan does not recommend Tranny Fluid flush at all strictly. But this page says Transmission Fluid Change @ 40K.
What is the difference between both?
When my transmission fluid was changed, the plates, and gaskets below were removed to drain fluid and were cleaned. Then transmission fluid was inserted by inserting a huge funnel above the dipstick...
What method is this? and is this correct?
2)Brake Fluid Change at every 40K.
I havent changed my brake fluid and im 115,000 on odo.
But the color is alright. Do i require a change?
3)Coolant at 80K.
I'm 115,000 on odo, and never had my coolant changed either. Everytime i go for service, the coolant has reduced between max and min level, and the service center fills their coolant.
What is this coolant change @80K and how important is it?
3)Coolant at 80K.
